Old 08-13-2019, 09:54 AM   #2
Default Re: Running cluster outside of car - mileage stuck?
Going by the diagram the Speedometer/Odometer just needs power, ground and signal to work. Ground & signal pins are on a different connector from the power pin.
The description of the signal required sounds pretty picky, if the square wave isn't 0-12v and a true square it won't work properly.
File Type: jpg 1999 IP Cluster Connector View-black.jpg (144.7 KB, 5 views)
File Type: jpg 1999 IP Cluster Connector View-natural.jpg (129.6 KB, 5 views)
File Type: jpg 1999 S-Series Gauge wiring diagram.jpg (176.8 KB, 7 views)
