Thread: BCM bad
Old 09-17-2017, 03:40 PM   #7
SQLGuy
SQLGuy is a jewel in the roughSQLGuy is a jewel in the roughSQLGuy is a jewel in the rough
Default Re: BCM bad
Next to the microcontroller is a small IC (8 pins) labelled 95040. It's an EEPROM. It's possible that contains the key data, it's also possible that it contains the VIN data. And, I suppose, it's also possible that it contains neither, or both.
Anyway, if it were me, I would try swapping the 95040s between the two boards to see if this either transfers your VIN to the good board or reenables storage of key data on the bad one.
Add to SQLGuy's Reputation
Rate the quality of this post and help SQLGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SQLGuy is offline   Reply With Quote
