Old 01-25-2018, 10:30 PM   #14
skylanedriver21
skylanedriver21 is on a distinguished road
skylanedriver21's Avatar
2007 VUE 3.5L
Default Re: 2006 Saturn Vue Blower Motor Totally Inop
If your DON'T have a problem with the big connector on the driver's side, you may have a motor with worn out brushes. That was the diagnosis a friend of mine (and former Mr. Goodwrench) helped me to. I have intermittent operation of the motor on all speeds and after checking everything about, I spent $50 with Rockauto and 30 minutes swapping out the full blower assemble. 2 7mm self tappers for the "close-out" panel and 3 8mm self tappers for the blower assembly itself. Much easier than some of the horror stories I have heard on other makes. Thank you, Saturn Product Engineering; wherever you are now.
Add to skylanedriver21's Reputation
Rate the quality of this post and help skylanedriver21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skylanedriver21 is offline   Reply With Quote
