Old 06-15-2008, 04:28 AM   #14
wolfman
wolfman's Avatar
Default Re: Wheel-bearing "gravity" Install--for Real?....
It has to be pressed, and using the CORRECT arbors. No if's and's or but's about it. Installation is actually a TWO STEP process. The bearing is installed and is then subsequently properly supported / reinforced with the proper tool / arbor while the hub is installed into the knuckle. There simply is no other methodolgy that will work and have the assembly be correct and maintain a service life of more than a few thousand miles. (IF that)
Add to wolfman's Reputation
Rate the quality of this post and help wolfman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolfman is offline   Reply With Quote
