Old 07-04-2018, 10:10 AM   #3
kg6mvb
kg6mvb has a spectacular aura aboutkg6mvb has a spectacular aura about
kg6mvb's Avatar
2003 ION-1 Sedan
Default Re: A/C fan not working.
My Ion has an ECM problem triggering the fan as well. The ECM should pull one pin to ground to trigger the fan relay (which it doesn’t). Jumping it to ground turns on the fan.
Rather than replacing the ECM, I wired up a relay to turn on the fan anytime the AC compressor is powered. I also added a switch so I can turn the fan on in the winter. The only time I need that is when sitting in traffic (or drive through lines).
You have a different model so of course YMMV.
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
Add to kg6mvb's Reputation
Rate the quality of this post and help kg6mvb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kg6mvb is offline   Reply With Quote
