Old 12-17-2019, 09:39 AM   #11
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Default Re: 97 SW2 Manual RPM's rev up while Hwy driving in 5th gear.
My original instrument cluster in mine would have the rpm's randomly jump a bit, I think it was the stepper motor getting stuck, or something slightly jamming the needle. I swapped out clusters for another one and the problem went away.
As indicated above, in 5th gear and press the throttle to the floor, if the rpm's smoothly rise above what you think they should, most likely clutch, but if the tach jumps suddenly or is twitchy, it's something else - electrical or cluster
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
