Old 11-01-2019, 03:14 PM   #3
Mobile785
Mobile785 is on a distinguished road
Default Re: 2007 Vue Redline P0113
The voltage across the leads with the sensor unplugged bounces between 4.99 and 5V When the sensor is plugged it started at 3.14 and slowly dropped as the engine warmed up. When I clear the ECU I hear the throttle body opening and closing, I'm not sure if that's normal or not on this vehicle when clearing the codes? The P0113 code returns almost immediately after clearing the code without even having to start the vehicle.
Sorry for the multiple updates. Tried to work on this in between work calls.
Jimmy
Add to Mobile785's Reputation
Rate the quality of this post and help Mobile785 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mobile785 is offline   Reply With Quote
