Old 10-07-2019, 12:09 AM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: 2007 Saturn Vue Green Line (Hybrid) 12V battery not charging redux. Also, cut wi
The cut wires are from a recall back in 2008. The connector and harness that is connected to the starter generator is a replacement for the cut off wires during the recall. The belt is ok? You need diagnostic trouble codes to diagnose. The battery energy control module is likely bad, The newer updated BECM had a short harness 1' and with an extension harness that connected to the body harness near the back of the left rear door, if you buy from a bone yard get the new module with short harness and extension harness, the fan also has a different connector and will be needed.
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
