Old 03-23-2019, 04:17 PM   #9
Wayne G.
Wayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to all
2001 L-Series 3.0L Sedan
Default Re: Low washer fluid and it's not the sensor... repair update
In mine thanks to to info from Dach, is fixed. There IS a grounding block just in front of the battery tray under the radiator fan control with probably 10/12 small black wires going to it and one large white wire. One of the small wires had been pull hard at some point and broken. Spliced in a 2" piece of wire - all working. This block also is the grounding point for the headlights as well.
Add to Wayne G.'s Reputation
Rate the quality of this post and help Wayne G. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wayne G. is offline   Reply With Quote
