Old 04-12-2013, 09:55 PM   #3
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
Default Re: Corroded Pipe for Thermostat and Housing?
You might want to get another mechanic.
There's 1 bolt that holds the T'stat Housing Extension Pipe.
After removing the bolt, it unplugs from the T'stat Housing - with some wiggling.
(2 O-rings at the arrow)
You then have to remove the Intake Manifold to unbolt and remove the T'stat Housing.
http://www.saturnfans.com/forums/att...5&d=1283999373
Add to Chazberry's Reputation
