Old 10-14-2018, 01:45 PM   #5
Default Re: No start, no spark
Ok, your answers seem to point to lack of spark. I forgot to ask - removing spark plugs should reveal wet plugs as indication of a good crank sensor and engine computer operating injectors to spray fuel into each cylinder while controlling the ignition system for spark. A dead crank sensor won't allow the engine computer to run at all - no spark, no injector pulses, no fuel pump operation while starting and driving, a dead EFI system. Checking for fuel on plugs verifies 99%of the EFI system is operating. Loss of ignition/spark points to the ignition control module, coil pack and wiring.
