Old 05-27-2004, 01:51 PM   #8
wolfman
wolfman's Avatar
Default
That is a LINEAR ELECTRONIC EGR valve. It has NO 'solenoid" but is controlled and monitored directly by the PCM. That EGR control circuit code with that unit is usually do to either a bad or loose wiring harness or connector at the valve itself, a blown fuse, or a loose or bad connnection at the TPS or ECTS (or bad ECTS) as it's data is used to indicate to the PCM when to start actuating the EGR valve in relation to engine temperature.
Add to wolfman's Reputation
Rate the quality of this post and help wolfman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolfman is offline
