Old 05-27-2004, 10:01 AM   #7
Luke
Luke will become famous soon enough
Luke's Avatar
1995 SL2
Default Check your Oxygen Sensor Also
Eljefino
Fabulous picture with your detailed outline and explanation. With my simple brain -- it works for me. Please continue to do it. Thank you.
BTW, SYEHT, in as much as you've had to change your EGR (probably from carbonizing), it would be a very good idea ( granted, I'm repeating myself ) to also change your O2 sensor, as they are good for about 50,000 & when they begin to become "sluggish", one of the results is carbon in the EGR,causing it to sticking, leading to an SES light/code.
> 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline
