Re: Back-up Camera
Don't think there's anything in the cabin to tap into other than the actual reverse light wires, but in the engine bay you're looking for either of the spliced connectors (pic is from a 5spd swap and the plugged in sensor is the reverse light sensor on the 5spds); the wire colors may change but they stay in the same position on the 6pin connector.
http://www.impact3d.com/manual_swap_...wiring_mod.jpg
