Old 04-08-2007, 05:27 AM   #6
SaturnManiac
SaturnManiac is on a distinguished road
SaturnManiac's Avatar
Default Re: Removing the door trim panels
Originally Posted by Dan76 View Post
Window crank. I think the door handle comes off with screws.
Removing the window crank is fairly easy, you can probably just stick a thin flat-blade screw driver behind the crank (I have done this before) and there should be a little clip, and this should release it....be careful though...so it doesn't fly too far. Once that clip is removed the crank handle should easily just slide off. Make sure you don't lose the clip, you will need to put this back on during re-assembly.
R.I.P. - My 1996 Saturn SL2, "Psycho" - 7/95-2/17/06
R.I.P. - My 2000 Saturn SL2, "Sexy" - 11/24/99-8/05/08
If you're a car begging for your life, wouldn't you want someone to add fluids?
SaturnManiac is offline   Reply With Quote
