Old 09-17-2012, 11:33 PM   #9
edefisio
edefisio is on a distinguished road
Default Re: changed ECTS now temp guage not woorking
OK, i re-connected the "original" sensor without inserting it into the cylinder head, reset the PCM as you suggested, and turned the ignition on and the temperature gauge came up to about 1/4, so that is a good sign and I guess would imply that i got a bad sensor or wrong sensor from the parts store?
Both the original sensor and the connector looked good with no bent pins or visible signs of damage.
I will need to wait until the car cools down to put the original sensor back into the cylinder head.
As an FYI... The code with the "NEW" sensor is P0117 - "engine coolant temperature circuit" - Low Input.
Thank you very much for the advice!
Add to edefisio's Reputation
Rate the quality of this post and help edefisio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edefisio is offline   Reply With Quote
