Old 12-02-2008, 11:48 AM   #12
jeepinwi
jeepinwi is on a distinguished road
Default Re: Shift Flare TSB question
Just so you know, you'll also need the entire under hood wiring harness since the Aisin TCM has different connectors, and the Aisin trans also has more sensors. Be sure to get all three transmission mounts with the Aisin since it has different bolt patterns for the mounts. Another little thing that is different is the mounting bracket for the PCM and TCM.
jeepinwi is offline   Reply With Quote
