Old 09-16-2017, 08:19 AM   #2
Default Re: Rear Disc conversion
It's a direct bolt-on swap from any '91-'97 DOHC w/ABS (SOHC's still had the option of drums w/ABS '91-'97 but can be used if they have rear disc). Rear disc was dropped entirely starting in '98.
The only "gotcha" is the parking brake cables, for a SL/SW you should be good with cables for a '96-'97 SL/SW. The cables are the same length for both brake styles but the tab on the end of them are just enough different you can't swap between disc & drum. '91-'96 SC cables are roughly 3" shorter than every other model because their shorter wheelbase is taken out on the poor rear seat foot-well, so don't get those cables for any SL/SW.
I'll never buy another '80's/'90's GM with rear disc, the looks and ease of working on them is not worth the requirement of tearing apart every 4-6 months ('89 Gutless Supreme went through calipers yearly, 3 S-Series with rear disc had to at least be re-greased every 5-6 months if not replaced).
