Old 10-16-2017, 09:49 PM   #12
billr
Default Re: Used transmission installed, but shift pattern is wrong.
Okay, I see the OP has already checked and swapped the solenoids; but how about the fuses? Yeah, a bad fuse should set a code, but it is easy to check those. Live-data is rapidly becoming the next logical (and easiest) step.
Add to billr's Reputation
