Old 10-15-2017, 04:26 PM   #5
5littlejoe5
5littlejoe5 is on a distinguished road
2000 SL1
Default Re: Used transmission installed, but shift pattern is wrong.
Originally Posted by toggenburg View Post
Just out of curiosity, did you only use Dexron III compatible transmission fluid or something else in it?
Our cars cannot and must not use Dex IV or VI....ONLY Dex III.
Also, was the trans you got, from a SOHC or a DOHC saturn?
Yes The ATF that was used was Dexron III compatible according to the label on the container. And I was told that it would fit a 2001 or 2002 Saturn SL1. It bolted right in place, and all the connectors came out right. Mine is a SL1 year 2000, but my understanding from various sources is that it should be the same from '98-02
Add to 5littlejoe5's Reputation
Rate the quality of this post and help 5littlejoe5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
5littlejoe5 is offline   Reply With Quote
