Old 11-18-2015, 09:10 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Passenger front seat belt
I never had mine apart, but would think that the assembly shouldn't be hard to figure out, IF you have all the parts.
Probably the bushing goes in first, place the spring on over the bushing then washer(s) on top of that to hold the spring compressed.
If in doubt, gently undo the other side seatbelt and see how it goes together.
