Old 05-17-2018, 11:20 PM   #10
FutureSat
FutureSat has a spectacular aura aboutFutureSat has a spectacular aura aboutFutureSat has a spectacular aura about
2002 L-Series 2.2L Wagon
Dizzy Re: L200 Parking Brake Issues
On my 2002 saturn LW200, the parking brakes never worked. like you I just put it off and finally got around to replacing it. 4 disc brakes front & rear..
First thought- Cables which looked rusted.. replaced both sides
Parking brake still does not work..
Further inspection, there is a spring mechanism located at the bottom of the rear disc brake housing where the parking brake cable feeds into under the bottom rose bushing.. this spring looks like a tension that pull the cable back when disengaged. Passenger side had the spring, driver's side spring was missing..
added spring from scrap yard.
Next up will be taking off the rear wheels and take off the calipers and discs to visually inspect the condition of the parking brakes..
Most likely after all this above ^^ was done is that everything inside the parking brake housing will be seized and rusted to crap.. Thanks Ontario Canada.
Add to FutureSat's Reputation
Rate the quality of this post and help FutureSat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FutureSat is offline   Reply With Quote
