Old 03-22-2009, 09:59 PM   #12
born again
2000 L-Series 2.2L Wagon
Default Re: Log: Timing belt replacement
Originally Posted by bigbird View Post
After reading the whole thread there really is something to be said for chain driven cams that require no replacement.
Timing chains also need to be replaced. They (in theory) make noise before they break or skip teeth. This allows you to change it before bad things happen. A belt gives no warning. This is why you change them at specified intervals. Warning - Saab for the same engine calls for a 100,000km (63,000mi) timing belt change interval. I wouldn't stretch this out too far.
