Old 09-27-2017, 08:38 AM   #2
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Re: Limp mode when I accelerate or use air codition
Change your mechanic, then get a scanner with live data and monitor all sensor outputs to see if one is giving questionable readings. I would start with the O2 sensors.
If the check engine light is on please post the codes that were set.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
