Old 02-21-2007, 01:38 AM   #4
Default Re: ABS making grinding noises
Posting without pertinent information related to your vehicle doesn't help as harsha has asked you about your brakes and if its time to replace them. Less a guessing game for everyone. Post more information.
If you have an owners manual read it. No owners manual then Google ABS systems and read up on how, when , where, and why ABS works. The more you find for yourself the more you'll benefit from the basic knowledge of ABS operation. If you are reluctant to try engaging your ABS brakes then there are several ways to check it. This is assuming your brakes are operational.
1-Arrange a service appointment with your local Saturn service center with the explicit purpose to have them check the ABS system to verify the ability of your vehicle's ABS operational capability. Nothing more, unless you approve any other service Saturn brings to your attention.
2-One alternative is to find an enclosed race track and ask for authorization to perform an ABS brake test by yourself or to have someone you designate to test your vehicle's ABS system.
3-The other alternative, and important if you've done some research to understand the workings of ABS systems, is to find a large even leveled lot covered with snow, to allow some amount of poor traction, free of obstructions for an abbreviated straight acceleration up to 30-40mph, and plenty of braking room at the end of this straightaway should anything wrong occur. A rain soaked lot will suffice also. Be absolutely sure there is room for mistake if the car should drift off to one side. This is at your own risk and be aware at all times prior to and during the ABS test. By experiencing a safe ABS test engaging your vehicle ABS system you will have first hand experience as to what will occur when the brakes are jammed to the floor completely, duplicating as near an example of a panic stop situation as possible without actually being in a panic stop.
When forcefully applying the brakes and NOT letting off, the ABS system will immediately react the moment any wheel locks up creating a skidding potential. You may hear the ABS motor but you'll definitely feel the brake pedal pulsate very fast as if a vibration is causing a problem in the brake system. This is the human/machine connection telling you the ABS is operating to unlock the skidding wheel and allow it to rotate at the same speed as the other wheels then reapplying the brake(s) according to the ABS computer that monitors all wheel speeds. All the wheels will be controlled by the ABS system, when operating correctly, as long as you forcefully apply the maximum braking effort and NEVER release the brake pedal as you come to a controlled ABS stop. This is the physically felt feedback built into virtually all vehicle ABS brakes and allows the driver to steer with as much control to avoid a collision while continually braking to a stop much more so than if there were no ABS installed. A snow covered lot is the best low traction environment to experience vehicle ABS without endangering you, anyone, anything near you short of an enclosed race track. Do this alone or with one other person as you will be surprised the first time if you've never experienced brake lock up or ABS operation. The slow speed is more than enough to engage ABS without overshooting miscalculations of side drift, if any, or not allowing run out room straight ahead. Of course it is assumed that safety belts are worn lest you desire being tossed through the windshield. Leave the cameras and loose paraphernalia home as they'll get tossed around. Take a serious attitude when performing this and you'll come away with a brief exposure to ABS but don't assume this will get you out of a jam as imbeciles have learned the hard way that even ABS won't save them from idiotic speeding while maneuvering close to other vehicles then suddenly finding themselves braking for their life only to find themselves rear ending the car in front of them!? To sum it up, ABS is for panic stops when one least expects it and still no guarantee of safe stopping and avoidance if the speed was far above road conditions.
