Old 07-14-2015, 09:46 PM   #13
Gritsngravy711
Gritsngravy711 is on a distinguished road
Default Re: Throttle Position Relearn
So, I am also having a problem with my drive by wire system as well. I was getting an error code of p2135 so I replaced my throttle body. It was used. When I first installed it appeared to have fixed the problem.bi didn't have to run a relearn procedure I just disconnected the battery. A few days later, it started going in to low power mode.most of the time it does it, sometimes it doesn't.I've tried the above procedure to do a relearn but to no avail. Any suggestions?
Add to Gritsngravy711's Reputation
Rate the quality of this post and help Gritsngravy711 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gritsngravy711 is offline   Reply With Quote
