Old 04-23-2014, 07:35 PM   #11
Default Re: Throttle Position Relearn
Excellent! If possible, if the throttle actuator is apart, mind posting pictures? I've kept my meddling fingers off my throttle actuator when replacing a stubborn t-stat a few years ago. I was intrigued when a member from Alaska opened his throttle actuator on his 3.0L Vue after replacing it with a used one from ebay. His only remarks were that there are familiar parts within that may be serviceable. I'm not tempted to play with mine unless absolutely necessary and/or have a back up in case failure occurs.
Thank you for following up.
