Old 04-05-2014, 06:05 PM   #5
Penrod
Penrod has a spectacular aura aboutPenrod has a spectacular aura about
Penrod's Avatar
2009 Outlook XE
Default Re: Throttle Position Relearn
As soon as I turn the key on the throttle plate goes through the movement and doesn't go through the relearn process at 29 seconds. I'm pretty sure I took the throttle body sensor apart further than I was supposed to, but now I'm getting the idle relearn code. Before I actually replace the throttle body assembly, is the throttle plate movement supposed to happen right away or is it supposed to wait the full 29 seconds? The throttle plate also doesn't mimic the pedal movement with the key on/ engine off.
Add to Penrod's Reputation
Rate the quality of this post and help Penrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Penrod is offline   Reply With Quote
