Old 12-17-2008, 09:41 PM   #13
Cheyne
Cheyne will become famous soon enoughCheyne will become famous soon enough
2000 SL2
Default Re: 1998 saturn won't start
Have you tried cranking it with WOT? Crank while holding the gas pedal down to shut off the injectors and open the throttle body.
Since you said that it cranked faster while trying to jump it: How old is the battery? Have you checked for corrosion at the terminals and battery cables?
You checked for spark at the towers. How old are the plug wires and have you checked their resistance?
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
