Old 03-16-2012, 01:30 PM   #9
dcflh07
dcflh07 is on a distinguished road
Default Re: 2001 sl ignition wiring diagram
after running all the wires for the ignition system, I found two connector's pins corroded(at the connector on the side of the for crankshaft sensor and the knock sensor) and the ground case ground for the powertrain control module.
cleaned and removed the corrosion the system works normal. thanks again for the wiring diagrams it help greatly.
Add to dcflh07's Reputation
Rate the quality of this post and help dcflh07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcflh07 is offline   Reply With Quote
