Old 03-10-2012, 06:06 PM   #8
dcflh07
dcflh07 is on a distinguished road
Default Re: 2001 sl ignition wiring diagram
thanks fdryer
got the drawings, #6 is the one,now I can check the wires, I now see another item I did not check the knock sensor.If the wires run out good I will have to check the inputs and outputs from the pcm to each component( will have to get the valves).one other thing I'm going to do is check for error codes. thanks again this helps
Add to dcflh07's Reputation
Rate the quality of this post and help dcflh07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcflh07 is offline   Reply With Quote
