Old 03-09-2012, 10:09 PM   #3
off-track
off-track's Avatar
Default Re: 2001 sl ignition wiring diagram
+1 on checking and re-checking the crank sensor and connector (as well as fuses).
Re-wiring is really extreme (and probably unnecessary) unless the harness fried/melted.
If you pull the wires off of the 4/1 coil pack and crank the engine does it arc between the terminals?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
