Old 05-02-2016, 11:08 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
Default Re: Code P0733 - Shifting Problem - SL2 2002
Welcome aboard - good job with the research. Since you have experience opening the VB, I would first try swapping the LP and 3rd Gear Solenoids with 2 of the others to see if anything changes.
Btw - ATF on that connector doesn't usually cause a problem - you are mostly concerned with overheated/burned contacts that are not making good contact.
Add to Chazberry's Reputation
