Old 08-17-2015, 12:12 PM   #61
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
Default Re: Have You Experienced the Ignition Switch Issue?
Here was the final disposition.
Was offered for $115 to troubleshoot then apply if things other than recall were affected. If only the recall fix was needed, the diagnostic fee was refunded. I told them to just fix the recalled items and if the problem persisted, I would fix the rest myself. He agreed.
Two recalls were addressed: 9100400 for ignition switch replacement and 9100495 for replacing ignition lock cylinder and key.
No work to the housing was necessary. 2.5 hours and $0.00.
First time I have ever been satisfied by the dealership service center.
For anyone else who can't shut their engine off, see photo for the green plug you want to disconnect.
Thanks to all!
Add to VentureForth's Reputation
Rate the quality of this post and help VentureForth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VentureForth is offline   Reply With Quote
