Old 03-28-2011, 12:58 AM   #4
radi
radi is on a distinguished road
Default Re: Tire Size Help (widest tire on OE wheel)
Originally Posted by SaturnFix View Post
You can use 195/60R14 tires, so long as you are using conventional NGK spark plugs. Premium spark plugs generally cause the wheels to overspin and interfere with the strut.
You can prevent that wheelspin problem by installing a used resin-tip ECTS, a cheap aftermarket EGR, and a Bosch universal O2 sensor.
OP: Please ignore the non-tire related commentary, it is not relevant. Spillover from a different thread.
Add to radi's Reputation
Rate the quality of this post and help radi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
radi is offline   Reply With Quote
