Old 06-16-2006, 10:07 PM   #3
wolfman
wolfman's Avatar
Default Re: 95 SL1 SES codes 22 and 76
Bad connection (perhaps a wire broken internally INSIDE the insulation where you can't see it) at the TPS or MAP harness or harness to sensor connector.
Or LOOSE main harness plug or corroded contacts at the PCM main harness plug connector.
(Hence the intermittant nature of the problem)
Add to wolfman's Reputation
Rate the quality of this post and help wolfman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolfman is offline   Reply With Quote
