Old 01-03-2018, 04:18 PM   #3
Ionizen
Ionizen is on a distinguished road
Default Re: LW200 Timing Chain Tensioner and Upgrade???
Thank you again for your time. From prior posts here I had the feeling the tensioner upgrade was not compatible. Good to have confirmation that itís not.
Iíve been to the GM site once for recall info but did not get a straight forward answer on prior recall work. Iíll try again.
From the fluids changed when I bought the car it looks as if oil changes were not done as frequently as I would have. I have ran several short OCIís with BG EPR engine flush. Finally the oil isnít looking dirty 300 miles after a fresh fill. Iím going to do an Auto RX treatment then switch over Mobil 1 extended performance.
I can only hope to put the mileage on that you have with no drive train repairs. Thanks again for your time.
Add to Ionizen's Reputation
Rate the quality of this post and help Ionizen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ionizen is offline   Reply With Quote
