Thread: battery drain
Old 12-15-2017, 02:59 PM   #20
billr
Default Re: battery drain
OP, how cold is your weather now? How short is your typical drive? How long is the car sitting without use?
Point is, frequent 5 mile trips are no problem for me, and letting the cars sit for several weeks (even a month +?) is no problem. No battery tender, of course. I only charge batteries if they have been sitting several months, and even then just to be sure they stay above 12V to avoid sulfation.
Use of a battery tender may help you, but may also be just a crutch to mask the real problem.
Temperature does affect your "battery experience", and I am in a mild environment, hence the question about your temps.
Personally, I prefer the Interstate batteries...
Add to billr's Reputation
