Old 07-09-2014, 05:15 PM   #5
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Default Re: upper motor mount-torque axis mount/dog bones
I would use OEM mounts as you will have more problems afterward with vibrations in the cabin if you choose the cheap aftermarket units.
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
