Old 05-12-2006, 02:37 PM   #4
DecayingOmega
DecayingOmega is on a distinguished road
Default Re: Down Pipe/Header Pipe/Flex Pipe/Front Pipe
Originally Posted by jcs444
If you don't mind replacing the converter along with the front pipe you could buy a direct fit catco converter/front pipe (one piece) from discountconverters.com for your car for $138.50 USD. It is catco part number 4068 and is stainless steel. You could probably install it yourself if you don't mind working with rusty bolts, it is a bolt in installation with three bolts at the exhaust manifold and three bolts at the flange behind the converter.
Yeah, sounds like the pipe to me. My old 92 Honda Civic did that, it blew a hole if the pipe that just kept getting bigger. I got it fixed at Midas for like $150 (New stainless steel pipe).
Add to DecayingOmega's Reputation
Rate the quality of this post and help DecayingOmega reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DecayingOmega is offline   Reply With Quote
