Old 09-06-2016, 12:28 PM   #62
Default Re: Minor Street Build Questions
A bit more info on the rack de-powering: http://sixthsphere.com/showthread.ph...ual-conversion
Dual intake cams (best done with a timing chain replacement): http://sixthsphere.com/showthread.ph...ntake-cams-2-*
Throttle body from a DOHC Geo Storm (GSI? not sure...), hard part is boring out our IM to take advantage of the nearly 1/4" larger bore TB and slightly relocating the throttle cable: ID The TB and install it
Fidenza 7lb aluminum flywheel (might be only steel 10lb options now, not sure)
Total upgrade option list, way out of date because most of the company's went belly-up 5-10 years ago Performance Parts Info but it's better than wondering what is (or..."was") out there.
From the junkyard to the track engine build
