Old 08-19-2008, 08:52 PM   #2
geartooth94
geartooth94 will become famous soon enough
geartooth94's Avatar
Default Re: Will a 1997 saturn sc1 manual transmission work in my 1998 manual sl2?
yes everything will bolt up and work correctly. however if you have cruise, it might get a little wonky because the gear ratios may be different. check differentracing.com to be sure.
also, your acceleration will be slower because each shift will drop you lower in the rpm band, away from the sweet spot of the DOHC engine.
1996 Dodge Avenger ES: 2.5L V6
geartooth94 is offline   Reply With Quote
