Old 02-21-2007, 12:41 AM   #3
madpogue
1996 SW2
Default Re: ABS making grinding noises
Originally Posted by Cortana View Post
ABS is tough to blindly test since I can't find a good way to be braking, sliding, and examining the ABS system at the same time
Um, dry pavement, empty street. Stand on the brakes. If none of the tires squeal, the ABS is kicking in.
Also, to isolate whether it's the ABS or the brakes themselves, pull the ABS fuse and do some test stops.
