Old 08-05-2015, 06:11 PM   #85
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
Default Re: "S" Series automatic transaxle fluid/filter change
Originally Posted by Bdpennington View Post
Does it typically use all 7 quarts?
The total capacity is 7.25 Qts. You will only get about 4 Qts out when you remove the drain plug. Most of the remainder stays in the Torque Converter - some in the Valve Body.
Add to Chazberry's Reputation
