Old 12-14-2011, 11:34 AM   #81
jamesq
jamesq is on a distinguished road
Default Re: "S" Series automatic transaxle fluid/filter change
I changed the ATF in my previously owned 98 SW2 this past weekend, but I have a lingering concern.
*The dip stick says use Dexron IIE.* I let it drain probably 40 min. until it was dripping ever 20 seconds or so. I then filled with 4 qts. started it up, ran for several min., went through the gears, put in park and checked the level. It was reading way on the low side. So I added .25 qt. and went for a short test drive. Still showing 3/8" below the "Ok" range. At the risk of over filling, added another couple ounces. Still says low.
So, did the previous owner switch dipsticks for some unknown reason?
Add to jamesq's Reputation
Rate the quality of this post and help jamesq reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jamesq is offline   Reply With Quote
