Old 04-26-2018, 09:05 AM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
Default Re: 98 SL2 serious noise/vibration issue, now with video!
Did you replace the front wheel bearings yet? One good wack with a hammer, to remove a stuck rotor or something, will wreck bearings.
Buy a set of used front steering knuckles from Arizona and then install them with new struts. The Arizona wheel bearings might even be good still. If they arenít, at least the Arizona knuckles will be rust-free and the bearings will be relatively easy to change.
Car-part com
Add to bumpdraft's Reputation
