Old 04-25-2018, 09:20 PM   #2
toggenburg
toggenburg's Avatar
Default Re: 98 SL2 serious noise/vibration issue, now with video!
Vibration AND that noise?
Vibration in the steering wheel? Didn't notice body shaking or the steering shaking.
Noise? Is it present during idle or just while moving down the road?
If you haven't modified the exhaust system, it sounds like some exhaust leak up front...exhaust manifold, down pipe, missing an O2 sensor maybe?
Might want to look at the engine at idle, then pull on the throttle and get the rpms up to 2K and watch engine movement....or even video it for us here to view too.
