Old 04-25-2006, 06:21 PM   #7
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Re: How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pict
Originally Posted by proton777
So, two questions. On item #2, do you have any suggestions on getting to the Torx bolt that is at the bottom right corner of the door? It's the one under the hinge. I've tried everything to get that thing out without success. Now it is in pretty bad shape.
Yea that one is a PAIN. I believe i used a ratchet and a socket torx bit and squeezed in there. You could probably try a "universal joint" and an extention.
1996 SC1
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline   Reply With Quote
