Old 10-02-2005, 02:51 AM   #44
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
Default Re: Changing the ECTS Coolant Temp Sensor (with pictures)
I would also like to add that I found it hard to remove the air intake on my SL1 because of that narrow tube that branches off the middle of the main air intake. So what I did instead was remove the battery as someone else suggested.
If I had to do the procedure again, I would place a towel or rag under the ECTS to catch the half a cupful or so of coolant that leaks out as someone else photographed.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline
