Old 01-20-2018, 03:08 PM   #1
JJF65
JJF65 is on a distinguished road
Default I have a 2006 Saturn ion 5 speed manual transmission
Posts: l transmission
I have a 2006 Saturn ion 5 speed manual transmission 2.2 engine. My problems started when I had a sunroof leak which I believe shorted out something in the electrical system because Iíve lost all power to the radio. Key would not start car changed ignition switch didnít fix the problem. Changed crankshaft sensor, mass flow sensor, ran fine for 30 minutes then lost power in 1st and 2nd gear, motor runs smooth and 3rd, 4th, and 5th have correct power, very weak power in 1st and 2nd. I am the original owner all maintenance has been kept up to date and I have 94,000 miles, I am a woman who needs help.
Add to JJF65's Reputation
Rate the quality of this post and help JJF65 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JJF65 is offline   Reply With Quote
